5th Generation Maxima Head Unit Removal Step 1: Open the ash tray and remove the tray/liner. Below you will see a phillips head screw. Remove the screw and set aside Step 2: Remove the upper air vents by prying from the bottom-right corner. The vents will not want to come out, so some force is […]
G35 Stereo and Climate Control removal
This DIY will show you how to remove the Stereo/CD/Radio unit and the Climate Controls out of your G35. Tools Needed: Small Flathead ScrewdriverPhillips ScrewdriverCup or Tray to collect screws (Optional) Step 1: Unclip trim at base of shifter. Push down to release. Step 2:Remove gold C clip from shift knob. Step 3:Unclip bezel around […]
