Maxima Rear Sway Bar Install
The following directions can be utilized in the installation of an Addco RSB onto a 5th Generation (2000-2003) Maxima. Installation onto a 4th generation (1995-1999) should be similar. It is recommended that two people perform the installation, but, one person could accomplish the task. Please view pictures with steps for additional detailed information. Step 1. […]
Filed Under: I30-I35 Articles, Maxima Articles Tagged With: 5th generation maxima, addco, handling, maxima, suspension, sway bar
5th-Generation Maxima: Remove Stereo
5th Generation Maxima Head Unit Removal Step 1: Open the ash tray and remove the tray/liner. Below you will see a phillips head screw. Remove the screw and set aside Step 2: Remove the upper air vents by prying from the bottom-right corner. The vents will not want to come out, so some force is […]
Filed Under: I30-I35 Articles Tagged With: 5th generation maxima, head unit, maxima, Nissan, stereo
5th-Gen Maxima Coilover Installation
Special thanks for this write up goes to Fezzik (David Honey). Posted with permission from the author. Here is what the rear coilover that I tested looked like compared to the stock rear suspension. These are still being tested and are not offered yet. You will first want to measure the car’s wheel gap right […]
Filed Under: I30-I35 Articles, Maxima Articles Tagged With: 5th generation maxima, coilovers, how to, maxima, Nissan, suspension
5th/6th-Gen Maxima – How to Reset ECU
How to reset ECU in 5th and 6th Generation Maxima’s 1. Turn ignition switch on and wait about 3 seconds. Repeat the following steps (2a and 2b) procedures quickly five times within 5 seconds. 2a. Fully depress the accelerator pedal (HARD).2b. Fully release the accelerator pedal. 3. Wait 7 seconds, fully depress the accelerator pedal […]
Filed Under: I30-I35 Articles, Maxima Articles Tagged With: 5th generation maxima, 6th generation maxima, cel, check engine, ecu, maxima
