How To Fix an Incorrectly Installed Lower Timing Chain
November 22, 2009 by Greg
1991-1994 Nissan 240sx This article will cover how to fix an incorrectly installed lower timing chain without removing the lower front cover.  If you have to turn your distributor all the way to the right or left to get it close to correct timing, chances are this is your problem. If you can not get […]
Filed Under: 240sx Articles Tagged With: bolt, bolts, cam chain, cam sprockets, compression stroke, crank pulley, cylinder head, egr tube, ka24de, nicoclub, Nissan, nissan 240sx, notch, s14, spark plug, sprocket, tdc, technical forum, timing chain
