1991-1994 Nissan 240sx This article will cover how to fix an incorrectly installed lower timing chain without removing the lower front cover. If you have to turn your distributor all the way to the right or left to get it close to correct timing, chances are this is your problem. If you can not get […]
Replace Timing Chain on a 240sx
Technical Articles: Replacing the timing chain on your Nissan 240sx Can I replace my own timing chain (or, better yet, why would I want to)? First, a few simple hints. Pull the front tires off to improve access. It helped a bundle. Be very careful pulling the drive pulley off. I broke one of the […]
Fix Your 240sx Timing Chain Rattle
Get rid of the noise coming from the front of your valve cover by removing the two guides for the upper chain. The guides are considered unnecessary by Nissan as seen in their TSB.
