By: Anonymous Basically, this is a solution to the dreaded CEL that many of us get from switching to testpipes. The idea is to place a gap between the pipe and the sensor to reduce the amount of exhaust gases that the sensor will see/detect. This is becoming a very popular mod over since it […]
5th/6th-Gen Maxima – How to Reset ECU
How to reset ECU in 5th and 6th Generation Maxima’s 1. Turn ignition switch on and wait about 3 seconds. Repeat the following steps (2a and 2b) procedures quickly five times within 5 seconds. 2a. Fully depress the accelerator pedal (HARD).2b. Fully release the accelerator pedal. 3. Wait 7 seconds, fully depress the accelerator pedal […]
Altima Manually Pull and Read Check Engine Light Codes CEL/SES
This article shows you how to read/pull the fault codes, usually accompanied by a Check Engine Light or Service Engine Soon, on your Altima with push button start. You do not need an OBDII code reader or any other special tools to do this. To take a reading without using an OBD II reader, you […]
