Overview: This DIY is to help install a G35 style Spoiler with brake light on the Altima Coupe Difficulty: 3 Time: 1 – 2.5 hours hours depending on skill level and how carefully everything is done People: possible with one, easier with 2 (for holding purposes and lining it up (second opinion)) Cost: To get […]
Technical Articles: EX35 Welcome Lighting Reset Procedure
How to reset welcome lighting on an Infiniti EX35 The welcome lighting is a feature that illuminated lights under the rear view mirror. This is a great feature as the car comes alive when you walk up to it. The standard detection rate is ~1 meter depending on signal strength from the transponder. If you […]
General Altima OEM to LED Bulb Replacement
General Altima OEM to LED Bulb Replacement Overview: This article is to help you install LED in place of the OEM incandescent bulbs.So since nobody’s ever made a write up, and there seems to be a question about it every week, i figured i’d do a write up for everyone. Difficulty: 2 Time: 1 – […]
