How To Replace a Broken Wheel Stud
October 28, 2009 by Greg
Nissan/Infiniti Vehicles $5.00 45 minutes NICOclub Rating System PapaSmurf2k3 I seem to break wheel studs fairly frequently (this is the 2nd time it has happened on this car), so I’d be willing to bet someone else is going to have this problem in the future. So here we go! Before starting you need to buy […]
Filed Under: Infiniti Articles, Nissan articles Tagged With: broken wheel stud, how to replace, replace stud, replace wheel studw, stud, wheel
How to replace a wheel bearing hub assembly on 07 + G35’s
May 14, 2009 by Greg
Here are instructions on how to replace a wheel bearing assembly on an Infiniti G35. The noise of a failing wheel bearing sounds like a brake caliper is sticking and leaving your brake on one wheel. I described it as a friction noise but I have heard it described as a whirling noise? You will […]
Filed Under: G35-G37 Articles, Wheel and Tire Articles Tagged With: G35, how to replace, infiniti 35, wheel bearing assembly
