LED Lighting Maxima Auto Gear Shifter
December 10, 2009 by admin
TOOLS NEEDED:
Soldering iron
Rosen core
6 White 3mm LEDS (preferred) or 5mm LEDS
6 470 Ohms resistors
Breadboard
Dremel
sand paper
Flat head screwdriver
Hot glue gun
Heat shrink
Snap or slide connectors
First, remove the gear selector trim from the car. Remove the shifter trim, then remove the 4 screws holding the gear selector trim. Then remove the bulb socket. the gear trim is held by 4 plastic tabs, just lightly pry each one around. Disassemble like shown:
Second, cut out a piece of the breadboard to fit it in the gear selector like so.
Goal is to try to get it sitting as low as possible, so more light output can dissipate, and reduce hot spots.
Third, Wire your LEDs:
Add a dot of hot glue, to keep close connections from shorting out.
Solder on + and – connections, wrap with electrical tape, then heat shrink. Afterwards, lightly sand off the tip of the LEDs to reduce hot spots
Fourth, refer back to Step Two. Place board as low as possible, then hot glue both ends.
Results:
it appears a rather bluish b/c of the blue overlay underneath the display. There’s nothing you can do about that.
Now, go cut off the stock bulb harness. Then connect it to your LED wires:
Reassemble, and your done
One other side note. For the last 2 LEDS, displaying gear 1 and 2, you will be able to see some of the white light from led itself, off to the side in the passenger seat. You can tell slightly in the picture above. Not necessary, but I went ahead and took care of it. Just get a 1/2 inch high x 1.25 inch long piece of plastic, and stick it beside it. You can use black electrical tape as well.
Article by: G4nismo
Filed Under: Maxima Articles Tagged With: automatic, how to, led, lighting, maxima, Nissan, shifter
3rd-Gen Maxima water pump replacement
3rd-Gen Maxima Fuel Injector Replacement
Installing a PCV Blow-by Oil Catch on a Nissan Maxima/Infiniti I30
5th-Generation Maxima Y-pipe and Cat installation
Maxima and I35 Airbag light reset procedure
Nissan Maxima 2002-2003 HID bulb replacement
Nissan Maxima: LED interior lighting
2002-2003 Nissan Maxima – Upgrade foglights to HID
Custom Tint on Maxima tail lights
Replacing Infiniti I30/ Nissan Maxima valve cover gaskets.
