Altima Coupe Racingline Rear Endlinks Install
You need– TWO 2-ton jackstands– ONE jack from the trunk– ONE ratchet with a 17mm socket– ONE 17mm wrench– ONE 19mm wrench OR locking pliers (I used the locking pliers) first you are going to need to jack the car up. Jacking points: You take your cheapo jack from the trunk of the car underneath […]
Filed Under: Altima Articles, Product Review Tagged With: altima, altima coupe, end links, how to, Nissan, sway bar
Cheap 240sx Sway Bar Link Upgrade
How to: Cheap 240SX Sway Bar End Link Upgrade! BY: Dano Our cars are old, so are the stock rubber bushings. Chances are your stock swaybar endlinks bushings are dried, cracked and rotting. Here’s a cheap solution, AND you can get all the parts from your local Autozone for under $30! Tools and Supplies -12mm […]
Filed Under: 240sx Articles, Nissan articles Tagged With: end links, polyurethane bushings, sway bar
