1967 Datsun WRL411 Rescue and Restoration (Part 7)
June 17, 2010 by Greg
  • 1967 Datsun WRL411 Rescue and Restoration - Part 1
  • 1967 Datsun WRL411 Rescue and Restoration (Part 2)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 3)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 4)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 5)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 6)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 7)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 8)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 9)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 10)
OK, you’re still with us – This is where it gets fun. Bex and I hope you’re enjoying reading about our restoration as much as we enjoyed doing it! The front sway bar bushings were virtually nonexistent, as time had taken its toll on them. I wanted to use polyurethane bushings here, but finding the […]
Filed Under: Datsun Articles Tagged With: engine mounts, front sway bar, front wheel bearings, mineral spirits, polyurethane bushings, spindles, sway bar bushings, synthetic grease, tie rod ends, tie rods
Cheap 240sx Sway Bar Link Upgrade
How to: Cheap 240SX Sway Bar End Link Upgrade! BY: Dano Our cars are old, so are the stock rubber bushings. Chances are your stock swaybar endlinks bushings are dried, cracked and rotting. Here’s a cheap solution, AND you can get all the parts from your local Autozone for under $30! Tools and Supplies -12mm […]
Filed Under: 240sx Articles, Nissan articles Tagged With: end links, polyurethane bushings, sway bar
