I got a quote of $220 to replace my valve seals and go over my head, and thought that was a little absurd. So, I decided to take the plunge and do it myself. There really isn’t much to it, after its all said and done. You just need the right tools that can be […]
How To Remove Cylinder Head from a KA24DE Engine
KA24DE Engine N/A 20 minutes NICOclub Rating System S13xCrazy Is it rocket science? Nope. Did I figure a couple people would be beneficial from it? Absolutely. If nothing else, this will give you an idea of what you are up against and shows how easy it really is. I have owned about 10 240sx, and […]
How To Fix an Incorrectly Installed Lower Timing Chain
1991-1994 Nissan 240sx This article will cover how to fix an incorrectly installed lower timing chain without removing the lower front cover. If you have to turn your distributor all the way to the right or left to get it close to correct timing, chances are this is your problem. If you can not get […]
How to Build a 9000-rpm SR20DET Head
An excellent article on how to rebuild a head for your Nissan SR20DET.
