1967 Datsun WRL411 Rescue and Restoration (Part 7)
June 17, 2010 by Greg
  • 1967 Datsun WRL411 Rescue and Restoration - Part 1
  • 1967 Datsun WRL411 Rescue and Restoration (Part 2)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 3)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 4)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 5)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 6)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 7)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 8)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 9)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 10)
OK, you’re still with us – This is where it gets fun. Bex and I hope you’re enjoying reading about our restoration as much as we enjoyed doing it! The front sway bar bushings were virtually nonexistent, as time had taken its toll on them. I wanted to use polyurethane bushings here, but finding the […]
Filed Under: Datsun Articles Tagged With: engine mounts, front sway bar, front wheel bearings, mineral spirits, polyurethane bushings, spindles, sway bar bushings, synthetic grease, tie rod ends, tie rods
1997-2001 Infiniti Q45 installing new strut mounts
By GQ Jay. Monday’s project: broken strut mount on the 97t. replaced: LF strut, bearing, mount, dust boot, gasket.while in the area, did the left rack boot and the sway bar bushings.would have done the sway link [more on that later]. since i wanted to change rack boots anyway, and i get nervous about ripping […]
Filed Under: Q45 Articles Tagged With: control arm, how to, infiniti, infiniti.q45, strut mounts, sway bar bushings, tension rod, y33
