1967 Datsun WRL411 Rescue and Restoration (Part 9)
June 17, 2010 by Greg
  • 1967 Datsun WRL411 Rescue and Restoration - Part 1
  • 1967 Datsun WRL411 Rescue and Restoration (Part 2)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 3)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 4)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 5)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 6)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 7)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 8)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 9)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 10)
Becky and I got started early on a Saturday morning, and we had the engine in within an hour. We ran into a couple minor snags – the motor mounts on a 411 are ridiculously hard to line up properly, and I inadvertently left the speedometer drive cable off the transmission until after it was […]
Filed Under: Datsun Articles Tagged With: brake bleeder, displacement, fuel pump, motor mounts, speedometer drive, stall speed, stroker motor, throttle linkage, torque converter, transmission crossmember, vacuum pump, valve cover, wiring harness
