1967 Datsun WRL411 Rescue and Restoration (Part 9)
June 17, 2010 by Greg
  • 1967 Datsun WRL411 Rescue and Restoration - Part 1
  • 1967 Datsun WRL411 Rescue and Restoration (Part 2)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 3)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 4)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 5)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 6)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 7)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 8)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 9)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 10)
Becky and I got started early on a Saturday morning, and we had the engine in within an hour. We ran into a couple minor snags – the motor mounts on a 411 are ridiculously hard to line up properly, and I inadvertently left the speedometer drive cable off the transmission until after it was […]
Filed Under: Datsun Articles Tagged With: brake bleeder, displacement, fuel pump, motor mounts, speedometer drive, stall speed, stroker motor, throttle linkage, torque converter, transmission crossmember, vacuum pump, valve cover, wiring harness
Infiniti Q45 Fuel Pump Replacement
By: tangalora One morning, my 1990 Infiniti Q45 (125K miles) wouldn’t start: The 4.5 liter 8-cylinder engine cranked wonderfully, but would not catch. It wasn’t the starter motor nor the battery (as it rotated perfectly). As always, it had to be either gas, air, spark, compression, or timing. Following is an idealized path others can […]
Filed Under: Q45 Articles Tagged With: cars, fuel pump, how to, infiniti, nico, q45
Fuel Pump Kill Switch
Fuel pump kill switch By:driftin8ez This mod is a good security feature as well as a helpfull diagnostic tool. If your car is having trouble starting you can use a fuel pump kill to see if it is getting to much fuel and flooding out. Also if hidden it makes a great anti-theft device. What […]
Filed Under: 240sx Articles Tagged With: fuel pump, fuel pump relay, kill switch
