1967 Datsun WRL411 Rescue and Restoration (Part 9)
June 17, 2010 by Greg
  • 1967 Datsun WRL411 Rescue and Restoration - Part 1
  • 1967 Datsun WRL411 Rescue and Restoration (Part 2)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 3)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 4)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 5)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 6)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 7)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 8)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 9)
  • 1967 Datsun WRL411 Rescue and Restoration (Part 10)
Becky and I got started early on a Saturday morning, and we had the engine in within an hour. We ran into a couple minor snags – the motor mounts on a 411 are ridiculously hard to line up properly, and I inadvertently left the speedometer drive cable off the transmission until after it was […]
Filed Under: Datsun Articles Tagged With: brake bleeder, displacement, fuel pump, motor mounts, speedometer drive, stall speed, stroker motor, throttle linkage, torque converter, transmission crossmember, vacuum pump, valve cover, wiring harness
With the interior done, we were set to put some miles on our new acquisition. Just for fun, I threw on a set of GAB Sport wheels I sourced from Japan. They were sitting around from an abandoned previous project, and they looked good on the car, and saved me from having to buy new […]
Filed Under: Datsun Articles Tagged With: compression test, crank, datsun, datsun roadster, exhaust manifold, front suspension, gab sport wheels, pistons, stroker motor
